L3400 grinding and shifting problem
   / L3400 grinding and shifting problem #1
praha
Chicago suburb
Kubota L3400 gear
My new L3400 grinds every time I shift from neutral. When in gears /loader work/ it is OK.
MY dealer told me , that I have to wait 2 seconds, hold the pedal for at least 2 seconds before shiffting. Sometimes that is not enough, it has to be held longer and I must be very gentle and carefull to move the shifter into the gears without that terrible grinding sound.
I should be able to push the clutch and shift ..without waiting!!!
Please, tell me what you think about it.
Thanks,
Joe
   / L3400 grinding and shifting problem #2
Are you coming to a complete stop? You must be stopped, clutch pushed in then shift. 2 seconds sounds long. As long as you are not moving you can clutch and shift right away.
   / L3400 grinding and shifting problem #3
I'm with Shimon: you have to be stopped all the way,and it'll shift without a clash. ..... forget about 2 seconds, but completely stopped, then you can shift without a clash. If anything different have your dealer try it. 2 seconds is .....! and you shouldn't need to listen to that stuff.
My 8N doesn't need that and it's 55 years old.
simonmeridew
Absolutely,
the tractor is not moving at all when it happens.
The dealer said that I would have to live with it. It has 17 hours on it and it has this problem from day 1. It is at the dealer right now and I think I am not taking it back unless the problem is solved.I paid a premium dollar for it and I should get a working product. Am I wrong?
Joe
   / L3400 grinding and shifting problem #5
It's an unsyncronized transmission. Any relative movement between the two gears you're trying to engage will produce grinding. How is the dealer going to solve that? The only thing that would be in the dealer's control and can cause excessive grinding is a dragging clutch and I would expect that the dealer has ruled that out.
You have to think about what's going on in the transmission before you try to change gears and the amount of time you have to wait varies. The rpm of the engine has a huge effect on this.
The part about having to be stopped isn't a hard and fast rule, either. I shift my L3000 between 5th and 6th all the time while mowing and rarely grind gears.
Maybe you should consider getting a hydrostat.
cp 1969,
the dealer said there's nothing they can do. They checked everything. They also talked to Kubota.
Again, I don't think I have to put up with it. I wasn't aware of this problem until I started using it. I paid a premium dollar for a broken tractor???!That's what I believe is not right and I think I should have a perfect tractor. My knee hurts after 2 hours , since I have to fight with the clutch all the time. Plus how long does it take to damage the gears?
Joe
   / L3400 grinding and shifting problem #7
Do you know if the dealer has tried adjusting the clutch linkage? It sounds like the clutch isn't fully disengaging. It also sounds like the dealer isn't really taking this seriously. It is possible the clutch disc, or pressure plate is defective. They'd have to split the tractor to get to it which may explain their resistance. You should not have to accept this condition. Ask the dealer to produce another tractor just like yours and see if it does the same thing.
IMHO waiting 2 seconds should not be necessary. If the transmission oil was really hot, and if the engine speed was over 2000 rpm, then MAYBE it would take a couple seconds for the viscosity of the oil in the transmission to bring the gears to a stop. But under normal operating conditions the tranny gears coast down very fast once the clutch is disengaged in neutral.
If you have a floor jack and stands you could test whether the clutch is dragging. With the wheels off the ground and the tractor safely supported, start it up and put it in a forward gear. Let the clutch out and the wheels should turn. When you push in the clutch they should stop. If they keep turning the clutch is dragging (not disengaging).
   / L3400 grinding and shifting problem #8
My Little 1980's something 15hp Mitsubishi grinds also, it is a non-syncroed tranny. If I wait for everything to spin down...a few seconds then it won't grind...grinding on a non-syncroed tranny is just the nature of the beast.
If you don't want to hear grinding gears...get a HST. Your knee won't get sore doing FEL work either.
   / L3400 grinding and shifting problem #9
praha said:
cp 1969,
Joe
If you think your tractor is broken, you need to ask the dealer to let you demo an identical model and see if it behaves the same way. If it doesn't, you've got a legitimate complaint. OTOH, if it does the same thing, it's like wushaw and I have said...it's the nature of a gear transmission--get a hydrostat if you can't live with it.
The thing is , I did not buy a hydro, I don' t want a hydro, I want a simple gear tractor...working as it should.
rbargeron,
they said they did all adjustments. Rpm was 900 and I have a problem shifting anytime, cold or hot.
I will ask the dealer to do the test you suggested. I think it is dragging , since sometimes I feel turning gears thru the shifting lever.. relatively long time after I push the clutch down.
The other demo does not do it.
Joe
Brandt Grain Vac - Mod. 5000EX (A59814)
Brandt Grain Vac -...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
2022 FORD F-250 CREW CAB TRUCK (A59823)
2022 FORD F-250...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
SCAN TO RECEIVE TEXT UPDATES (A60429)
SCAN TO RECEIVE...
2018 Chevy Silverado 1500 4X4 (A56438)
2018 Chevy...
