L3400 Engine Dying
/ L3400 Engine Dying #1
Milton Burro
Missouri
Kubota 3400
Starts and runs fine, but when I begin to let out on the clutch it dies. It's an intermittent problem that just began this evening. Any ideas from this panel of experts? I tried a search before I posted, and will try to check the seat switch tomorrow, just thought someone may know of another possible cause. 2008, 136 hours.
/ L3400 Engine Dying #2
Although probably not the problem, it takes only a second to check. . .
A year ago my 3400 died & I couldn't get it started. Turned out to be the bleeder on fuel line had come loose (from vibration???). As I recall its just above the filter - lil knob.
Good luck!
/ L3400 Engine Dying #3
Does it die like you are turning the key off or is it bogging down/stumbling/studdering???
If its just shutting off like you killed the key, I would TEMPORARILY bypass the various safety kills until you find which one is shutting you down....
/ L3400 Engine Dying #4
If it boggs down, check the parking break...:ashamed: don't ask why...
It dies like I'm turning the key off, push the clutch in and it picks up and runs again.
/ L3400 Engine Dying #6
Gear or HST? I played with my HST, unplugging safety switches and nothing like you said happen. I guess you have a gear (DT) is there a safety switch to have to have it in neutral... no that keeps the key from ever turning over the engine... humm...
Yessir,, manual trans. Perhaps there's a switch on the clutch?
/ L3400 Engine Dying #8
if it starts right up again as soon as the cutch is pushed back in i can bet its the seat switch or wires to that switch. make sure nothing is obstructing the seat fully engaging that switch. I know on my old JD i had a similar issue. it was the switch (nest under seat).
/ L3400 Engine Dying #9
I could unplug my seat Safety switch and start it from the ground... When I unplug the clutch safety switch, nothing happens with the key... same with the PTO. I'm at a loss...
/ L3400 Engine Dying #10
unplugging wont cure the problem. then the switch thinks it not operational. when you sit in the seat you complete the circuit. If you lnow which wires go where with the seat switch (mine had 3 wires) yo can cross feed the wires after its unplugged. this eliminates the switch. i would assume the same for the other safety switches. Though i could not think why the clutch switch would be the issue as the engine is already running. if you unplug the clutch switch, the tractor thinks the clutch IS NOT engaged and wouldnt let you start tractor. The PTO switch would be the same, it would make the tractor think the PTO is engaged and not let you start tractor if its unplugged. Im still betting its the seat switch.
If your comfortable with it, you can wire a jumper accross the terminals and see if the tractor can then drive foreward. if it can, the seat switch is the fault.
/ L3400 Engine Dying #11
I wonder if you have a herd of algae running around in the fuel tank and everytime you try to move it sloshes it enough to close the inlet screen?:confused:
/ L3400 Engine Dying #12
hes not moving it, hes simply depressing the clutch. and it revs back up if he depresses the clutch
/ L3400 Engine Dying #13
UGH!, maybe tis a sticky brake then after all????
/ L3400 Engine Dying #14
ya know, on my 4400 i can HEAR the fuel solenoid "click" when I turn the key on, then I hear another "click" when I turn the key off...... IF his tractor is the same, stands to reason he should be able to listen for the audible "click" when he starts releasing the clutch pedal...... this would tell us if its an electrical safety switch issue, or if its something else!!..
OP, Did you try releasing the clutch with the trans. in neutral, if so, what was the result?
I guess I wasn't clear enough on my first post. If pto is disengaged and trans in neutral, it doesn't die. I had to move my son across country the last few days so I haven't had a chance to look at it closer. Only when I have it in drive does it die.
/ L3400 Engine Dying #16
hhmmm... really sounds like the seat switch wiring... maybe someone on here has a wiring schematic they can post up to help trace the wiring... theres probably a way to temporarily bypass it
/ L3400 Engine Dying #17
The fact that it will start eliminates the PTO switch and that it will run in neutral eliminates the trans switch. I second the seat switch. To check the seat switch you will need a continuity tester. Unplug the seat switch from the wiring harness (there is a tab on the bottom that is hard to see, you may have to release the zip tie). There are three wires on the switch (black blue orange) that terminate in male pins in the connector. With the seat only all the way down there should be continuity between the black and orange wire only. With the seat only up there should be continuity between the black and blue wire only. Anything else and the switch is bad. If you need to drive it in the meantime, you can make a jumper with a a two inch piece of wire and two male spade connectors. Unplug the connector from the clutch switch and bridge the connector with the jumper. JUST REMEMBER, IT WILL NOW START IN GEAR WITH THE CLUTCH OUT!
Finally got around to taking a look at it. Seems the seat switch was the culprit. With the seat down, the switch was right on the edge of make/break position. I removed it to see if I could adjust the lever but it is on a hex shaft and pinned to fit in one position only. Not only that, a different position on the shaft would move it too far out of range. A pair of channel locks to bend the metal tab down a little that activates the switch was all that was required. Talk about taking the long way around,,,
Thanks for all the feedback.
Peruzzo Canguro 1600 Collection Flail Mower
Peruzzo Canguro...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
2006 Utility 53Ft T/A Reefer Trailer (A64194)
2006 Utility 53Ft...
2016 Peterbilt 579 Automatic High Top Sleeper (69") (A62613)
2016 Peterbilt 579...
2015 Isuzu NPR HD Septic Pump Truck (A62613)
2015 Isuzu NPR HD...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
