L3301 Cooling Fan
/ L3301 Cooling Fan #1
Blondie70
Poplarville, MS
Kubota L2501DT
I may have posted this before, but can't remember.....I would like to find a radiator fan that pushes instead of pulls. (like the kind I had on a dozer...would do both). I am tired of getting roasted operating this tractor in hot weather. I want a fan blade assembly to mount in place of the original one. Only thing I have found so far is electric fans...would far rather have one that is belt driven.
Thank you for any help...;)
/ L3301 Cooling Fan #3
It's not always optimal depending on blade design but is the blade mount offset the same on both sides? If so you could just flip the blade over and it will reverse the airflow.
I have a couple kubota engines and some this can be done on some it can't. Some just need a spacer to make it work.
Another thought, by reversing the airflow it could cause more heat buildup by the dpf etc. which is not what you want.
Could you make deflectors that can help prevent the air from the underhood area from blowing on you instead of reversing the airflow?
/ L3301 Cooling Fan
If I could flip the fan over and remount it....nothing would change...it would still be a puller. I am not concerned about the DPF. It will be fine. Deflectors are something I do not know about. I am kinda doubting that I could do this. The hot air is kinda enveloping the operator, not just a stream of air. Reversing the fan would solve this problem. Not having any luck tho...maybe after warranty goes out, I can try an electric fan.
Thanks for the help.
/ L3301 Cooling Fan #5
Yup you're right, the ones I was thinking about used an idler system to reverse direction after the fan was flipped.
That's what I get for posting on no sleep.
Electric would be your easiest option but I'm sure there's a fan out there somewhere
/ L3301 Cooling Fan #6
There are screens in front to protect the radiator. It keeps junk from getting pulled through. Reversing the flow puts the screen on the wrong side.
/ L3301 Cooling Fan #8
The screens come out.
Ya, but it's harder to get a screen before the fan or between the fan & radiator. My radiator plugged up fast enough with regular cleaning of the screen. I wouldn't roll without a screen personally.
/ L3301 Cooling Fan
I will keep it clean. It is worth that and much more to reduce the incredible heat on the operator in the hot weather. Like working in a furnace. Plumb nuts !
/ L3301 Cooling Fan #10
Have you thought about the heat that comes off the DPF when it is doing a regen? I'm not sure using a pusher fan would keep it cool enough under the hood when a regen is happening. I don't think it would be a problem during normal operation.
/ L3301 Cooling Fan
It will be just fine under there. A pusher is moving air, just like a puller. Besides, the pusher will be pulling cooler ambient air from the engine area...not hot air from the radiator....win win. I am not doing anything until this thing is out of warranty. Then it's cool down time. If the tractor melts I will let you know...ha ha ha.
/ L3301 Cooling Fan #13
Actually the tractor will run hotter with a pusher fan as it is sucking hot air from the engine and then having to cool it and the engine. Operator might be cooler but engine runs hotter.
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A60352)
2017 Gravely...
PALLET OF ROLLERS (A60432)
PALLET OF ROLLERS...
Paladin 12in Digging Tooth Bucket Excavator Attachment (A60352)
Paladin 12in...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A61306)
2023 Takeuchi TL6R...
