Good machine for the most part. But there could be some expensive "potential" problems lurking:
The GST clutch pack was a weak point, the clutch pack housing was'nt beefy enough where the snap ring holds the spring loaded clutch discs in the housing and may come apart.
An updated clutch pack housing is available for this unit and is covered under an extended period of 5 years parts and labor and 7 years parts only. The later machines have been updated at the factory and have the new style clutch pack. This repair will run you in the neighborhood of 3000 bucks if the failure occurs out of the extended warranty period.
The GST shifter cover (at the GST valve) was at first built with an o-ring to seal the shift shaft and did'nt hold up all that well. You can upgrade to the lip seal style shift cover for about
250 bucks.
The seals that seal the front drive shaft tend to work there way out and cause the transmission fluid to drain into the clutch housing area. This you can get upgraded for about 150 bucks.
If this tractor has a 3-point hitch mounted backhoe be sure the top link reinforcement bracket has been installed. Personnaly I'd recommend it for most implement applications except maybe a rear mount mower. It prevents the back of the rear housing from ripping out under increased top link loads.
The front axle kingpin seals are another weak point. They tend to require replacement every few hundred hours and will probably run you about 200 bucks per side per occurence.
Make sure the front axle holder upgrade was accomplished. The original front axle holders were too weak and would break usually causing damage to the ring and pinion and possibly the axle housing itself. Another repair that can squeek into the 1000's category.
These problems apply to the early production Grand L and
L35
tractors all of which have been corrected on the later production machines (with the possible exception of the front axle seals).
If this machine has seen regular visits to a good Kubota dealer
many of the upgrades may have been done; Front axle holder,front drive shaft seal spacer kit. The GST clutch pack problem is "fix as fail" and on a 95 machine will no longer be covered under warranty (well I guess depends on purchase date)
Just a list of stuff I'd want to know about before purchasing.
