IdahoRenegade
- Joined
- Mar 6, 2011
- Messages
- 3
- Tractor
- Kubota L3240
Tonight I fired up my tractor, drove it outside, and removed my fuel filter and cleaned the filter housing. I put the filter back in (was nice and clean), opened the fuel valve, and watched the filter bowl fill. The tractor fired right up and ran normally...for about 30 seconds and died. I figured I got some air in the line. I have tried opening the bleed valve and removing/reinstalling the filter. No luck. I have now tried cracking the nuts at the injectors to try to bleed....but it's currently on the charger due to running down the battery. (only ran for 10 seconds or so at a time). Anyway, any suggestions? I've changed fuel filters before and never had to bleed. I was low on fuel when I did this, have since added 5 gallons. Anything else I should try?
