Snow L3130 w/ L2172 snow plow
   / L3130 w/ L2172 snow plow #1
SteveA
Bronze Member
Connecticut
Kubota L3130
Anyone using this setup? Can't seem to find much info on the factory front plow blade kit.
From what I was able to find, the plow subframe has to be removed in order to re-attach the loader. (mine is the 723).
Is it worth the aggravation? I'm trying to stay away from one of those loader arm rigs or jury rigging a plow blade to my bucket.
   / L3130 w/ L2172 snow plow #2
Steve, yes the linkage has to come off. It is two pins and you should have it down on the ground to back off after unhooking your hoses.
Is there anything else that is needed in addition to the plow and the subframe? Are the existing hydraulics and controls off the 723 loader sufficient? Thanks.
   / L3130 w/ L2172 snow plow #4
I don't know which valve that you have but you should be fine. You could drop the whole frame and blade at once.. At that it is about a five minute change.
Any clue what the price range is for the Kubota plow and subframe assembly? Also, are there any after-market plow setups that will mount similar to the Kubota line? Thanks.
New/Unused 7ft 10 Drawer Work Bench (A48837)
New/Unused 7ft 10...
2022 Club Car...
2213 (A50460)
2213 (A50460)
2005 PETERBILT PB335 FUEL & LUBE TRUCK (A50459)
2005 PETERBILT...
(1) HD 24ft Free Standing Corral Panel (A48836)
(1) HD 24ft Free...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
