L3130 or L3400?....
   / L3130 or L3400?.... #1
ecologyman
Salem County New Jersey
nothing yet
Good morning friends.
I've been laboring over the decision for months and finally have my choice narrowed down to Kubota. Now my choice is between a 3130 and a 3400.
My local Kubota dealer gave me a price of $17,100 for a 3400 GST, FEL, and a 5' rotary mower. I thought that was pretty fair and have no complaints. He hasn't quoted me for a 3130 (I may go there today), same set-up, but I'm sure it can't be too much more. Ideally a 3430 would be my choice but I don't want to go too far over the 17K mark.
Has anyone done any homework on these models? Any opinions?
As always I am...
confused.
   / L3130 or L3400?.... #2
You beat me to the punch on this one. I am trading in my B7500 for a 3400hst but have read people having trouble with the 3ph on the 2800 and 3400. It seems it jerks upward and down when you need to make minor adjustments to the level.
Several Kubota dealers have said this is normal and if it is, I will stay clear of that model.
My questions:
Is there anyone out there not having this problem with the 2800 / 3400?
What is the price difference between the 3400 and 3430 with fel?
   / L3130 or L3400?.... #3
I would go with the 3130 for the upgraded hydro and smooth 3pt. given them choices.
The L2800 and L3400 are basic bare bones L series, not that there is anything wrong with them I have the L2800 and it has been great but the 3pt is not smooth.
Have the dealer put a box blade on the 3pt of the L3400 and L3130 you are looking at and just try it and see the difference.
   / L3130 or L3400?.... #4
I have the L3400 and it is jerky when you raise it but it is very smooth going down. I have never thought that there was anything wrong with mine but this is the only tractor I have owned except for a Farmall Super A. It was also jerky except it was jerky in both directions and impossible to adjust in anything but 2inch increments in either direction. My L3400 was such a vast improvement that I never considered that anything was wrong with it. It appears to me that if the lift was very smooth in the upward travel, it would not shake the clinging dirt off the box blade or other implement. If you want to raise an implement all the way up, move the lever all the way back rapidly and it will raise smoothly until it reaches the top and it will stop abruptly only once. I have been very satisfied with my tractor. I've had it over a year and had zero problems.
   / L3130 or L3400?.... #5
I also have a new L3400HST with 3.5 hrs on it right now. Yesterday I noticed the 3pt. jerk problem for the first time. So far I had only used the bucket of the tractor and not the 3pt. I currently have my chipper mounted and an excessive amount of chips were building up so I went to raise the chipper slightly to move the tractor forward and it really jerked. I thought it was just me but it did it repeatedly. Then I turn on the computer and I see you guy's are having the same concern. This is not right and Kubota needs to fix it. Just because we did not buy a Grand L does not mean we have to put up with a jerky 3pt. I wish I would of noticed this sooner. I also sent an email to Kubota. Will let you know what I hear. I really want ot like this tractor. Brian
   / L3130 or L3400?.... #6
I spoke to my dealer today and apparently Kubota uses the same 1" increment valve on the 2800 / 3400 as the 7800. If this is true, the jerkyness going up in small increments would be normal when you have alot of weight on the 3ph.
   / L3130 or L3400?.... #7
The B7800 has a quarter inching valve and the L2800/L3400 is position control. I have not used the quarter inching valve style but it does look different from pos cont where you can put the implement at the same spot everytime without messing with it.
   / L3130 or L3400?.... #8
Have just around 30 hrs on my L3400DT this spring -- love it!
"Jerky 3pth" makes me think of another post (?last year) when someone commented on their loader being 'too fast' and 'a bit touchy' or something like that. A poster responded with something to the effect that we're not supposed to mention such things and that we would get used to it. /forums/images/graemlins/blush.gif
I agree with ToJo. The 3 pth has been faster than I've been used to, but very functional once you get used to it. I supose if there wasn't such a short movement required on the control lever to raise an implement, it wouldn't appear so 'touchy'. It sure beats so many of the other machines I've used where the lift seemed to move like a geriatric elevator.
I've found that once I got used to where I needed to move the lever to in order to raise a mower, I could just move the lever in one smooth motion and the implement will raise smoothly too -- quickly, but smoothly.
Try them yourself!
Shawn
Thanks for the helpful replies. My wife and I have all sorts of irons in the fire right now and I don't need to scare myself into paying more for a tractor just because the less-expensive one has a "jerky" lift. Things always seem a little bizarre until you get used to them.
   / L3130 or L3400?.... #10
There is an adjustment for the downward speed of the 3ph on the L3400. But mine is also jerky on the way up which makes it difficult to smooth the drive. I just back up with the FEL in the float position to make the final pass, or drag with chain-link fence.
TAKEUCHI TB210R EXCAVATOR (A51242)
TAKEUCHI TB210R...
2019 PETERBILT 579 SLEEPER (A51222)
2019 PETERBILT 579...
(3) 40 RIG MATS (A50854)
(3) 40 RIG MATS...
2015 DODGE RAM...
2016 Ottawa Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, 33,000 ... (A51039)
2016 Ottawa Yard...
1984 NAVISTAR 1954 CABLE HOIST (A51222)
1984 NAVISTAR 1954...
