L3130 OPC Timer Relay
   / L3130 OPC Timer Relay #1
Squeak n Itch
Thumb of Michigan
Kubota L3130DT-F
I believe the OPC is the source of my random engine shutdown. There are four leads red, black, yellow and red/white. Can anyone shed light on which are the input wires and which are the output?
The OPC timer relay was indeed the problem. I replaced it this A.M. and all seems fine for now. I only wish that I had some way to bench test individual components and this whole process would have consumed less time and fewer $$.
   / L3130 OPC Timer Relay #3
Could you please provide the part number of the part you changed.
I ask because after looking at the WSM, your model tractor seems to be much more computer controlled than say the L3010 where the relay for the engine stop solenoid has a timer function and I am wondering on your L3130 if the relay is just a simple one and the timing function if being done by the 8 bit CPU in the intelli Panel
Dave M7040
   / L3130 OPC Timer Relay #4
Glad you got it fixed. Per the WSM, page 9-S38:
"Checking OPC Timer
1. Remove the timer. (OPC timer is located behind the panel)
2. Connect jumper leads across the battery positive terminal and
the timer 3 terminal, and across the battery positive terminal and
the timer 4 terminal.
3. Connect jumper leads across the battery negative terminal and
the timer 2 terminal, and across the battery negative terminal and
the bulb terminal.
4. Connect jumper lead across the timer 1 terminal and the bulb
terminal.
5. The bulb lights up when disconnecting a jumper lead from the 3
terminal 0.7 to 1.3 seconds late, the timer is proper.
(1) OPC Timer
(2) Load (Lamp)
(3) Battery (12 V)
A : OPC Timer Relay Side Connector 4A"
Looking at the OPC Timer Relay with the connector lock on the bottom, the relay terminals are as follows:
2 1
4 3
2018 Toyota RAV4 SUV (A50324)
2018 Toyota RAV4...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
2019 Isuzu NPR-HD 24ft. Box Truck (A50323)
2019 Isuzu NPR-HD...
CATERPILLAR 259D SKID STEER (A51242)
CATERPILLAR 259D...
2008 GMC C7500 Altec LRV55 55ft Forestry Bucket Truck (A50323)
2008 GMC C7500...
