L305DT manual question
   / L305DT manual question #1
Believer45
Cincinnati, Ohio
Kubota L305DT with Bush Hog 2240QT loader
Good afternoon, all.
I bought an L305DT 4x4 with a Bush Hog brand front loader a few months ago (great little tractor, by the way). I ordered shop tractor and engine manuals from my local Kubota dealer and what came was a workshop manual for an L345 & L345-II for the tractor and a manual for diesel engines that covers D1102-B, D1302-B, D1402-B, V1502-B, V1702-B and V1902-B engines. I have not been able to run down the actual engine designation for my tractor and want to be sure these are the correct manuals before I open the packages (I don't want to waste $106 and change if I can help it). Can anyone help with this one?
Thanks in advance.
Dave / Believer45
   / L305DT manual question #2
Hello Dave...
I believe it is a D-1301a
Could be a D-1302...
You will find this information stamped on the block,around the injector pump...
KennyV
Thanks, KennyV - I do appreciate the information. Do you know if the 345 and the L305DT are built on the same frame with the same driveline? I have two manuals and from what you are saying the engine manual is probably not identical to what I have.
Dave / Believer45
1999 MACK CH613 WATER TRUCK (A50854)
1999 MACK CH613...
2007 BIG TEX END DUMP TRAILER (A50854)
2007 BIG TEX END...
2015 FORD F750 BOX TRUCK (A51219)
2015 FORD F750 BOX...
2015 PETERBILT 367 HOT OIL (A50854)
2015 PETERBILT 367...
2014 PJ 24+6 T/A GOOSENECK (A50854)
2014 PJ 24+6 T/A...
2006 Ford F-550 4x4 Flatbed Pickup Truck (A50323)
2006 Ford F-550...
