L3010 Seat Stuck
/ L3010 Seat Stuck #1
dwest
Pampa,Tx
Kobota L3010
I just purchased a L3010 Hst. 900hrs. The seat won't slide. No one has mived it in the last few yrs. What would be the best way to get it lose so I can use it?
/ L3010 Seat Stuck #2
It appears that you have already tried to move the seat forward or backward by the travel adjust lever. Have you checked to see if the lever is bent? If you are able to tilt the seat forward, check to see if the tracks that the seat travels on are rusty, bent, cracked, or broken. Another thing that you can do, is look at the lower back of the seat and check out the suspension adjust handle. It may be causing some problem also. You stated that the seat's position has not been changed for a long time. If everything appears to be normal, spray some lubricant on the areas and give it time to soak in. It may take some time for the affected parts to move or slide. Sincerely hope that this helps somewhat. Best of Luck.
/ L3010 Seat Stuck
Thanks i will give this a try.
Thanks again
2016 FREIGHTLINER CASCADIA 125 T/A DAYCAB TRACTOR TRUCK (A59912)
2016 FREIGHTLINER...
UNUSED SDLANCH SDLGC80 ELECTRIC GOLF CART (A64280)
UNUSED SDLANCH...
2005 BOBCAT 323J EXCAVATOR (A64279)
2005 BOBCAT 323J...
2004 JLG 944E-42 TELESCOPIC FORKLIFT (A64279)
2004 JLG 944E-42...
Case SV280B (A60462)
2014 John Deere 310SK 4x4 Extendahoe Loader Backhoe (A61572)
2014 John Deere...
