L3010 HST-R, LA481 & 4672
   / L3010 HST-R, LA481 & 4672 #1
JimW1950
I am considering a used 2001/2002 Kubota L3010 HST-R with a LA 481 loader and a Kubota 4672 backhoe.
I am having trouble finding the specs on this unit. Kubota site, prior products was not helpful. Any suggestion, on where I might basic specs?
Any known problems with this Kubota model?
Thanks in advance.
   / L3010 HST-R, LA481 & 4672 #2
I have a 3010 with that loader. I love it. What are you going to do with it?
Power:
Engine (HP): 30
PTO (HP): 25.5
Engine:
Manufacturer: Kubota
Fuel: diesel
Cylinders: 3
Displacement (ci): 91.5
Compression:
Rated RPMs:
Torque (ft-lbs):
Firing order:
Oil capacity (qts):
Transmission:
Type: gear
Forward: 8
Reverse: 8
Transmission:
Type: hydrostatic
Forward: infinite
Reverse: infinite
MFWD: optional
Capacity:
Fuel (Gal): 9.2
Cooling (Qt): 7.4
3-Point:
Category: I
Lift (lbs): 3090
Power Take-off (PTO):
Type: live
Rear speed (RPM): 540,2000
Hydraulics:
Type: open
Capacity (gal): 10.3
Total Flow (gpm):
Outlet Flow (gpm): 7.0
Outlets:
Tires:
Ag front: 5.00-15 (7.2-16 4WD)
Ag rear: 12.4-24
Dimensions:
Weight (pounds): 2950
Wheelbase (inches): 65.7
Length (inches):
Width (inches):
Height (inches):
Ground clearance (inches):
Electrical:
Battery volts:
Ground:
Battery cold-cranking amps:
Alternator amps:
BLACK DIAMOND AIR COMPRESSOR (A53843)
BLACK DIAMOND AIR...
44029 (A51692)
44029 (A51692)
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
2000 GMC C7500 CRANE TRUCK (A51406)
2000 GMC C7500...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
