L3010 & B2910 Weight and Height ?
  • Thread starter scooksey
  • Start date
   / L3010 & B2910 Weight and Height ? #1
S
scooksey
Guest
Hello,
I sincerely appreciate all those that have posted their informative and yes entertaining posts!
I have a question, can someone post the weight and height of the L3010 & B2910? The height with both standard and foldable ROPS would be greatly appreciated.
I am trying to determine if it will fit in my garage while I build a shed. Also, I have an underpowered vehicle (170hp) and need to make sure I can tow the tractor, implements and trailor with what I have.
Thanks in advance!
Steve "the tarheel"
   / L3010 & B2910 Weight and Height ? #2
Steve. I'm pulling the L3010HST info out of the operators manual.
Weight with ROPS = 2745 lb
Height with ROPS = 83.9 in.
I don't know for sure but the height may change based on the tires. Also the weight will change based on whether you put ballast in the tires.
My L3010HST will not fit in my garage with the ROPS up. It misses it by 5/8 in due to the trim style on the garage.
Kevin Mc
   / L3010 & B2910 Weight and Height ? #3
Steve -
Don't know about the B2910, but I have an L3010 brochure in front of me that says the overall height, with ROPS is 84.3 inches. Doesn't specify the folded-down height, but it looks to be about shoulder-height if you were in the seat.
The weight (with ROPS) is listed at:
F (2WD) - 2560 lbs.
DT (4WD) - 2710 lbs.
GST (4WD) - 2720 lbs.
HST (4WD) - 2745 lbs.
What the heck -- get 'em both and see for yourself. /w3tcompact/icons/laugh.gif
   / L3010 & B2910 Weight and Height ? #4
Steve, the B2910 weighs 1763 lbs without any implements. None of the literature (brochure or manual) lists the height but I measured mine with folding ROPS at 88". Non folding is quite a bit shorter. Anything else?
Larry...
   / L3010 & B2910 Weight and Height ? #5
Kevin -
"<font color=blue>It misses it by 5/8 in due to the trim style on the garage</font color=blue>"
I had the same problem when I first got my 2500, but there is no folding ROPS option for that model. I posted my solution back in September. /w3tcompact/icons/smile.gif
   / L3010 & B2910 Weight and Height ? #7
I just went out to the garage and measured the ROPS height on my L3010 with Goodyear Turf Tires.
ROPS up = 81.75"
ROPS folded = 69.5"
   / L3010 & B2910 Weight and Height ? #8
I thought the B2910 was the same chassis as the B2710 which the Workshop Manual shows as 78.5" to the top of the ROPS. I think my canopy added about another inch, but it's no problem with my 7' garage door.
Bird
   / L3010 & B2910 Weight and Height ? #9
Bird, the height I quoted was with my folding ROPS. I'm sure yours is fixed considering you have a canopy.
Larry...
Thanks to all those that provided information.
You folks are GREAT!
Steve
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
7096 (A51573)
7096 (A51573)
2023 JOHN DEERE 8R310 LOT NUMBER 202 (A53084)
2023 JOHN DEERE...
2020 INTERNATIONAL MV607 24FT NON CDL BOX TRUCK (A52576)
2020 INTERNATIONAL...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
JOHN DEERE 54D LOT NUMBER 160 (A53084)
JOHN DEERE 54D LOT...
