L3010 50Hr Service Hints
   / L3010 50Hr Service Hints #1
boustany
Platinum Member
Campbellville, Ontario
Kubota L3010, BX2200
So, I spent the weekend in the cold doing my 50 hour service. It went pretty well, and I spent much more time waiting for the juices to drain than actually working.
If you are thinking of doing the service yourself, I have some tips:
1) Warm up the fluids by making the tractor work for about an hour. If you do, drain the UDT first, and be carefull because it may be hot. I didn't and the stuff took a while to drain out because it was so thick.
2) Get a bunch of drain pans and drain a few things at a time. There are usually 2 or more drain plags for each section and it goes twice as fast if you are draining both at the same time.
3) Watch the UDT drainpans - most pans have only a couple of gallons capacity, and there are about 10 gallons of HST to come out!
4) Make sure you have at least 10 gallons worth of empties to store the old oil and UDT in before your dispose of it in and environmentally sound manner.
5) When you want to remove the suction strainer (or whatever its called) for the HST, you can't unless you disconnect the return spring on the sliding lever for the HST peddle. Disconnect the spring, slide the lever back, remove the strainer, clean it, and replace it, remembering to reconnect the spring.
6) Make sure you have a big, strong, oil filter wrench. The HST and Hydraulic filters were on really tight and I actually ruined my filter wrench trying to remove one. It wasn't a very good wrench, though.
7) You will ned a variety of funnels to fill it back up again. Make sure the funnels for the UDT have a big spout, otherwise it will take forever to pour the fluid it. I believe you should never use the same funnel for oil and any other fluid like UDT, so I skeep them apart. Also, I use an old funnel for old oil/UDT, never a clean one.
Other than those little nuggets, its a pretty easy job. It would have been easier if it wasn't so darned cold out, but at least I was sheltered.
In any event, I figure anybody who can do an oil change can probably to the 50 hour service. It just goes easier if you are well prepared.
Have fun!
   / L3010 50Hr Service Hints #2
I recently went through that service myself, I had read that a typical 5 gallon plastic bucket wouldn't fit under my L3010, but I found that a 5 gallon mud bucket left over from my drywall job fit fine, with about 2" to spare, just enough to get my hand in between the bucket and the drain plugs. I agree about the filters, the filter on the left side was the tough one- I had to use a chain-style pipe wrench to get it off, even then it almost wouldn't budge.
   / L3010 50Hr Service Hints #3
The big thing besides what was mentioned is to allow enough time to do the job. Some of the plugs to be taken out are larger than what's in a typical wrench set, so I purchased what was needed as I did not want to use a crescent wrench. The filter on the left side is the HST filter. A normal band type filter wrench will not remove it. Either use a hammer and punch along the serations on the inside of the filter or a filter wrench made like vice grips to grip those serations. The new 3130 has no strainer.
   / L3010 50Hr Service Hints #4
Get a "three legged" filter wrench. Sometimes need to use two hands to get started, but they adjust for just about any size filter and I've yet to encounter a filter I couldn't remove with it.
   / L3010 50Hr Service Hints #5
FYI check the transmission filter part number! I dumped 10 gallons of fluid when starting my L3410 in 10 degree weather through the filter gasket in less than 2 minutes. The dealer came out and replaced the fluid / filter (same filter part number) and on the next cold start it did the same thing (although I caught it real quick). There is a Kubota service bulletin out that changes the trans filter part number on all of the Ten series Grand L's (according to a previous post here). The 3410 is for sure affected. The OLD number is #32701-37950. The replacement is #TA240-59900 or 01. The dealer sold me the old filter for my 50h service, and replaced it with an old one when they came out to fix it. Check it out, as my dealer was obviously not aware of this change.
   / L3010 50Hr Service Hints #6
For an oil drain tub, consider a large mortar tub. They are cheap ($12), and available from Lowes, Home Depot, and they hold about 15 gallons. I have an L3010 GST which holds just over 10 gallons. The mortar tub works great...and it's cheeeep. The only downside is transferring the old oil from the tub to a couple of 5 gallon buckets. You can cut the bottom out of an old 1 gallon plastic jug of any kind, and use it for a scoop.
Just another choice; might not be best for everyone. Your mileage may vary.
k
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
2004 CATERPILLAR 320C L EXCAVATOR (A60429)
2004 CATERPILLAR...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
