L3000DT hydraulics
   / L3000DT hydraulics #1
Anonymous Poster
Epic Contributor
does anybody know where to tap into the system of a L3000DT for operating other
cylinders? has anybody done this? if so i sure would appreciate any information you
can give me. thanks.
william in wright city, mo.
William,
You didnot mention if you had a loader on your L3000DT. I do on mine, and have been told by dealers, that you can hook up a spliter valve off the hydraulic control valve to your loader and use a separate hydraulic cylinder. You just give up use of your loader bucket if you use the other hydraulic cylinder.
Doug in Independence, Minnesota
   / L3000DT hydraulics #3
what doug says is true, we put a down pressure bush hog brand post hole digger on last week and that is how it worked you tie in the line that tilts the bucket and when you switch it you run your aux cyl off the loader handle if you dont have a loader then you come off the side of the lift cover i think contact your kubota dealer to be sure.
yes i do have the FEL. but is there a place to tap off of that is not related to
the operation of the FEL?and where would be a good place to locate the
valve?
william
2023 AVANT 735 COMPACT WHEEL LOADER (A51242)
2023 AVANT 735...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
Miller Bobcat 225G Welder (A49461)
Miller Bobcat 225G...
2019 MMDI 14ft T/A Utility Trailer w/ Fuel Tank (A48082)
2019 MMDI 14ft T/A...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
