L3000DT 3PH failure
   / L3000DT 3PH failure #1
Youare
Platinum Member
Winchester, New Hampshire
Kubota L3000
My L3000DT with 52 hours on it has returned to the dealer once again for a problem with it's 3PH./w3tcompact/icons/sad.gif
Shortly after the 10 hour mark the 3PH started going up and down all by itself for a little less than 1 minute. Then at 46 hours the 3PH failed to lift one day but worked okay the next day. This happened to be the day the dealer arrived to take it to the shop for this problem. /w3tcompact/icons/frown.gif
So I had them do the 50 hour service along with a FEL lift cylinder seal replacement they did as a warrantee item. I haven't used the FEL for much more than moving fire wood from the pile to the porch.
I used the 3PH twice after the tractor came back from the 50 hour service. Most of the time I used the tractor to pull a trailer when gathering maple sap. Last Thursday I lower the 3PH and when I went to raise it up nothing happened. This weekend it was still dead.
There is a big empty spot in the barn tonight. /w3tcompact/icons/sad.gif
Hope they get it fixed soon, the dealer said they may have keep it a week to 10 days.
Randy
   / L3000DT 3PH failure #2
<font color=blue>...may have keep it a week to 10 days</font color=blue>
Ooh, ouch! What a bummer /w3tcompact/icons/sad.gif Good luck. At least it sounds like they have an idea what the problem is and will really try to fix it this time.
Toyota 6FGU25 Forklift  5,000 lb Capacity (A51039)
Toyota 6FGU25...
2020 CASE CX37C EXCAVATOR (A51242)
2020 CASE CX37C...
2014 John Deere 8360R MFWD Tractor (A50657)
2014 John Deere...
2014 FREIGHTLINER CASCADIA (A50854)
2014 FREIGHTLINER...
2019 Kubota F3990 72 in. Commercial Mower (A50324)
2019 Kubota F3990...
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
