L3000 DT Hydraulic Problem
   / L3000 DT Hydraulic Problem #1
trudie1
Michigan
Kubota L3000DT
Help,
I have an issue that I can't seem to resolve, any suggestions would be appreciated.
I cut the wore through the hose from the tranny to the front bucket joystick control box. I replaced both hoses and all bucket functions are fine, but....the rear 3 pt. lift mechanism won't lift with the lever unless I roll the bucket up then the 3 pt. will lift just fine. Tried reversing the hoses to see if I crossed them up but no deal, nothing worked then.
Tractor is only 4 years old and only 200 hrs.
Any suggestions appreciated.
Thanks,
   / L3000 DT Hydraulic Problem #2
I had this problem with my 1910 when I changed the fluid. I don't think I added enough. I put more fluid in and it went away. It may also have been air that bled out.
   / L3000 DT Hydraulic Problem #3
This is a rank guess because I don't have direct experience with a L3000. Do you still have the old supply hose? There may be a sleeve at the valve end that the new hose doesn't have. The function of the sleeve is to enable the power-beyond port in the valve - which goes back to the hydraulic block to power the 3-point hitch. If the power-beyond fitting isn't there it is disabled and the 3pt would no longer operate independently. The power-beyond feature is accomplished differently on different valves so yours may be a loose piece, or part of the supply hose fitting, or inside a separate plugged port on the valve. Hope this helps you find the bug.
Thanks for the info, unfortunately I trashed the old hose, but I'll try the parts list.
2012 CATERPILLAR 336EL EXCAVATOR (A51242)
2012 CATERPILLAR...
2008 FORTITUDE MANUFACTURING 40X96 FLATBED (A50854)
2008 FORTITUDE...
(INOPERABLE) MAROOKA (A50854)
(INOPERABLE)...
2018 PETERBILT 579 SLEEPER (A51222)
2018 PETERBILT 579...
2019 Kubota F3990 72 in. Commercial Mower (A50324)
2019 Kubota F3990...
2010 SHOP MADE WINDMILL TRAILER (A50854)
2010 SHOP MADE...
