L3000 3PH ups and downs
   / L3000 3PH ups and downs #1
Youare
Platinum Member
Winchester, New Hampshire
Kubota L3000
I have not been real comfortable with the operation of my 3PH from the start. It seems a little eratic when I ask it to come up, it jerks up in 3 or 4 inch leaps no matter how slow I move the lever. The othe rday I was driving form one place to another with my winch on the back, about 400 pounds in the raised position when all of a sudden I noticed the winch would drop about 4 inches and then coame back to the orginal height. This happened about evey ten seconds. I dropped the 3PH then raised it again and the up and down thing stopped.
Anybody got any ideas, or had a similar experience. I am going to call the dealer soon.
Randy
   / L3000 3PH ups and downs #2
Yep, thats how they seem to work on the 3000's. Ya just have to be a little lighter on the touch /w3tcompact/icons/crazy.gif
Mark
   / L3000 3PH ups and downs #3
Yep my L2350 does the same jerking when lifting the 3ph. Not much you can do, I have tried to move the lever very slow, but it still jerks a lot. Makes it a pain using my potato digger.
Camshaft in Pa.
   / L3000 3PH ups and downs #4
My L3410 does not have any problems like yours. The 3PH is smooth and moves in very small increments. This is something I do a lot when the box blade is being used. Recently I got a post hole digger and that goes up and down a lot and needs fairly tight control. Once again, no issues. You need to see the dealer about it as it is not normal.
John Bud
   / L3000 3PH ups and downs #5
John, I have talked with the dealer and tried a few low end L series and they are real touchy on the up stroke. Nice and smooth going down, but it takes a steady slow hand to get the 3ph up without it "jerking".
Mark
   / L3000 3PH ups and downs #6
Mark,
<font color=blue>tried a few low end L series and they are real touchy on the up stroke.
Nice and smooth going down, but it takes a steady slow hand to get the 3ph up without it "jerking".</font color=blue>
Huh? Really? Either I have a smooth touch (yeah right, like a blacksmith!/w3tcompact/icons/wink.gif) or I have one that works correctly. Of course, now that I am thinking about it, my attachments are typically about 850 to 1200 pounds. That may damp it and result in a smoother operation. But....on 2nd thought, when I hook up something the arms are empty and I can go up in very small steps to align the pins into the arms.
Were I you, the dealer would still be my next stop.
Hope it all works out well!
John Bud
   / L3000 3PH ups and downs #7
John, I did go to the dealer (two of them), all the l3000's I tried were "jerky" with an attachment. None of the xx10 series I tried had this problem.
Mark
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
Caterpillar D7G Bulldozer (A50514)
Caterpillar D7G...
Brown 417 7ft Rotary Cutter (A50490)
Brown 417 7ft...
Ford F-450 Utility Truck (A51039)
Ford F-450 Utility...
Quick Attach EZ Axe Skid Steer Tree Shear (A51039)
Quick Attach EZ...
