L295DT tie rod
   / L295DT tie rod #1
Ed_L295DT
Massachusetts
Kubota
For owners of L295DT tractors - is the long tie rod between the wheels supposed to be straight? Mine has a slight upward bend to it. Thanks for checking.
   / L295DT tie rod #2
It should probably be straight, But is's really nothing to worry about. If your tractor is pulling one way or the other you can simply adjust the tie rod ends.
I had to replace a tie rod end when I bought my used tractor, the rod was bent and I straightened it a bit. I still need to adjust the toe a little bit but it's only pulls when on the pavement. In the grass or dirt I'm going slower and it's not noticeable.
good Luck,
Rob
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
Unused 2025 CFG Industrial QNT45 Mini Excavator (A50322)
Unused 2025 CFG...
2002 CASE INTERNATIONAL MX270 TRACTOR (A51243)
2002 CASE...
2011 INTERNATIONAL PROSTAR PREMIUM DAY CAB ROAD TR (A51243)
2011 INTERNATIONAL...
1990 Ford F800 7 Yd. S/A Dump Truck (A48081)
1990 Ford F800 7...
