L2950 aair sensor indicator light on
   / L2950 aair sensor indicator light on #1
double hunter
Ford 1715
I have a Kubota L2950 that has the air sensor light staying on all the time, changed the air filter and it is still on, how do you check the sensor or should I just replace it, I looked at the sensor and it has one wire coming off it and another piece that looks like a vent or ??, any help appreciated,
   / L2950 aair sensor indicator light on #2
I'd say the switch is bad, it is just a grounding unit!
   / L2950 aair sensor indicator light on #3
Pull the plug to the sensor and the light should go out. If it does it is the sensor.
AIR POWERED TONGS (A50854)
AIR POWERED TONGS...
2015 FORD F-250XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-250XL...
2011 MAGNUM PRODUCTS LIGHT TOWER/WATER TANK TRAILER (A50854)
2011 MAGNUM...
1985 International X Con Semi (A50514)
1985 International...
1999-2010 Ford Pickup Truck Bed (A49461)
1999-2010 Ford...
(2) ROLLS OF HD CHAIN LINK MESH WIRE (A50460)
(2) ROLLS OF HD...
