L295 transmission cover
   / L295 transmission cover #1
Calhoun Louisiana
Kubota L3430
I lost reverse on the L295 that I use and upon removing the gear shift lever assembly/cover I found the forked gear moving arm was broken for the reverse. I replaced it but then ran into the problem of one of the other forks would not slide back and forth like the others do. There are little ball bearings that hold the shaft (that the fork is connected to) in place when the particular gear is selected and I suspect this ball bearing is stuck. Try as I might I could not get it unstuck and have succeeded in cracking the housing where the ball bearing was stuck. So here is my question anyone know of a junkyard/used parts source for older kubotas, I understand this is a grey market tractor and was wondering if there is an american model equivalent?
   / L295 transmission cover #2
Contact Anna at Southern Global Tractor.
They have a web site .She can get it for you.
   / L295 transmission cover #3
Try West Kentucky Tractor Parts (270) 462-2191 They were able to help me find parts for an L245 and got them to me fast UPS. Ask for Robyn Crook. Good luck on the repairs.
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
2019 FREIGHTLINER CASCADIA DOUBLE BUNK SLEEPER (A51222)
2019 FREIGHTLINER...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
