L295 4wd
   / L295 4wd #1
stepdoctor
troutville virginia
kubota L295, JD 40W, International 140
Has anyone had experience with fixing the 4wd on a L295. How difficult is it to remove the front drive shaft? Any suggestions, Thanks
   / L295 4wd #2
The front drive shaft has three bolts holding the shield or cover on. You'll need to remove all three. Slide the back half of the telescoping cover forward as far as you can. On the shaft that is exposed there will be a coupling with a snap ring on both sides of it. Slid both snap rings out of the way. Drive the coupling towards the rear of the tractor, they sometimes put locktight on the shaft/coupling so you may need to use a tourch to losen the locktight.
Good Luck TROL
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2019 Komatsu PC490LC-11 Hydraulic Excavator (A49461)
2019 Komatsu...
12 Ft Enclosed Trailer (A50324)
12 Ft Enclosed...
2013 Ford E-350 Enclosed Service Van (A50323)
2013 Ford E-350...
STIHL TS420 CUTQUICK SAW (A50854)
STIHL TS420...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
