L2900DT exhaust oil leak
   / L2900DT exhaust oil leak #1
BertZegers
South-West Ontario
Kubota L2900, Zetor 8011, Kubota KX41Excavator, John Deere 4400 Combine, Case 1816C skidsteer
My L2900DT ( Dual traction) D1503 L-A has a oil leak at the exhaust manifold. I would like your opinion about what would cause this oil leak, and how to fix. After cleaning this is the oil it leaks after 4 hours run time. I did not notice loss of power, and no abnormal smoke.
The tractor is NON TURBO, shows 2200 hours and is most time not worked hard.
I tried to put a picture on this page, but I only managed to have a picture in a attachment.
   / L2900DT exhaust oil leak #2
Most likely not engine oil but unburnt fuel with exhaust carbon coloring. Short runs, not getting the engine up to operating temperature. Tractor needs to be taken out and had the snot worked out of it for several hours. Quit babying it.
   / L2900DT exhaust oil leak #3
Have you knowticed if crankcase level oil going down ? BTW the DT does not stand for dual traction . It means direct transmission , gear tractor .
   / L2900DT exhaust oil leak #6
I haven't been able to post pictures in over a month using TBN icon and still haven't figured the attachment out yet either.
Oil coming out of the exhaust manifold, that is weird.
   / L2900DT exhaust oil leak #7
Thats interesting first time I have heard it refered as dual traction . For years DT is , was known as direct transmission or gear tractor . The reference below contradicts Nelson's article . Anyway I don't want to derail Bert's original question .
What is this Shift? Understanding Kubota Transmissions — Humphreys' Outdoor Power.
l29dt kubota what does dt mean - Google Search
   / L2900DT exhaust oil leak #8
Oil must be getting by the piston rings or maybe exhaust valve somehow but if thats the case it should be burning oil and smoking more, crack block and compression would be lost.
2015 Chevrolet Express 4500 Shuttle Bus (A55788)
2015 Chevrolet...
SAKAI SV544 SMOOTH DRUM ROLLER (A52706)
SAKAI SV544 SMOOTH...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
2016 GMC SIERRA 3500 SERVICE TRUCK (A51406)
2016 GMC SIERRA...
24ft T/A Enclosed Cargo Trailer (A55758)
24ft T/A Enclosed...
2018 JLG 4045R 40ft Electric Scissor Lift (A55787)
2018 JLG 4045R...
