Hi,
I've been having some electrical issues with my L2900. The past few times I've had to start the tractor the starter would turn, but wouldn't turn over the engine. I usually have had to put a battery charger on it to charge the battery (it generally starts at 60-80%; it's either the alternator was loose on the belt which I just fixed or a dying ground wire, on my todo-list.). Once it's above 85% no problem starting. Well I tried starting it the yesterday and wouldn't start. I charged it then tried to start it and none of the dash lights would turn on. Tried jumping the ground wire as I have in the past. Nothing. No dash lights. I pulled the 40amp engine fuse and the 6 fuses in the cab area. All worked. I checked power at the engine fuse to chassis: worked. It was getting dark last night so I went inside to work on it this morning.
I turned the key for giggles this morning and the lights came up, but the starter wouldn't start and just had a whizzing sound then the lights went off and they wouldn't come on again. I then decided I should take the dash off and try to figure out where power goes or doesn't go and debug from there, but couldn't figure out how to get the dash off. It seemed like the speedometer was connected with a bar to the engine or something that I didn't know how to disconnect to lift it off.
Any suggestions on what to do short of hiring a tractor repair person/company to come give my tractor a complete physical exam?
