L2900 Kubota front loader trouble
   / L2900 Kubota front loader trouble #1
psalm
asbland city tn
L2900 Kubota
Loader wont go down.has a stiff hitch in its Getty up when you try to go down.seems to have little lifting power.
   / L2900 Kubota front loader trouble #2
A hyd gage would help you diagnose the problem and let you monitor and trouble shoot the hyd system.
Check fluid level.
Check all filters.
Check all QD's.
Make sure the return lines are not blocked.
Dopes the 3pt work correctly?
3 point works fine .all filters are new.I think there's something wrong with joy stick box but not sure.it doesn't feel right sometimes.and other times works fine.
   / L2900 Kubota front loader trouble #4
Is the joystick joystick operated or wobble stick?
Again, if you use a hyd gage, you can see every hyd pressure result for any operation.
Yes J J have checked all you listed. Don't have a gage and would not know how to use it. Joy stick works fine sometimes other times it does not thinking trash in joy stick box?
Wobble stick. J J
   / L2900 Kubota front loader trouble #7
Next time you use the joystick, remove the boot and watch the wobble unit to see if it is doing what your think it should be doing. How loose/sloppy is it, and is the spool moving in and out equally.
A hyd gage is a valuable tool to let you see what the hyd system is doing in terms of, the pressure for any hyd action.
You know there is a relief pressure setting on the loader valve, that protects the hyd pump.
So when you go to full extend or retract and hold it there, the pressure should register the relief pressure.
If you see no pressure when you move the lift part of the joystick, that tells you the flow is not there for the cyl to develop the pressure.
That is a gear pump on your tractor, and will try and pump as long as the tractor is running.
With all valves in neutral, the fluid just flows through each valve in a series flow path to tank.
If the hyd jerk around, there is probably air in the hyd system, and it will normally purge itself.
The air could be sucked in from a leak in the suction hose.
Very good info thanks J J
1996 Monon 45X96 Dry Van Trailer (A51039)
1996 Monon 45X96...
Case 84in Hydraulic Hopper Sweeper/Broom Skid Steer Attachment (A49461)
Case 84in...
2017-2022 Ford F-250/350 Rear Bumper (A49461)
2017-2022 Ford...
2012 Ford Escape XLS SUV (A50324)
2012 Ford Escape...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2020 Peterbilt 389 Tri-Axle Sleeper Cab Truck Tractor (A49461)
2020 Peterbilt 389...
