L2850 Tachometer Parts or Repair?? Help!
   / L2850 Tachometer Parts or Repair?? Help! #1
Popster
Bronze Member
Southern Maryland
Kubota L2850, 8N
The tach on my new to me L2850 does not work. I know that the cable is functional and that it is turning. The tach basically does not move. At high rpms it will bounce at the bottom a bit.
Has anyone ever repaired a tach? Anyone know a source for parts?
How about a source for a replacement tach?
Any info is appreciated.
BTT
Any info? Anyone ever attempt to repair tach?
   / L2850 Tachometer Parts or Repair?? Help! #3
Here is a link to a few tractor salvages in your area ...
Maryland Antique Tractor Parts and Equipment Sources | Antique Tractor parts & resources for Antique Tractors, Implements and Equipment in the state of Maryland
You really should edit your profile to show where your located. There may be folks near you that have what your looking for...
You can also contact these folks they have a lot of Kubota used parts..
West Kentucky Tractor Parts - Kevil, Kentucky
should not be too hard coming up with a used one .. and rebuilding one is not that bad... check with your dealer to see if the internal components are available... KennyV
   / L2850 Tachometer Parts or Repair?? Help! #4
KennyV in this great world of ours it is hard to find a gauge that is rebuildable!
2013 MACK CHU613 (A50854)
2013 MACK CHU613...
Unused 2025 CFG MH12RX Mini Excavator (A49461)
Unused 2025 CFG...
2015 FORD F350 SERVICE TRUCK (A51222)
2015 FORD F350...
Champion C80 B (A50322)
Champion C80 B...
2013 PETERBILT 367 (A50854)
2013 PETERBILT 367...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
