L285 utility
   / L285 utility #1
msjanket
Will the L285 pull a single bottom plow well? I would not use a 16 inch, more like 14 or 12.
If rears are loaded, can this unit function as a good and solid tractor for low to moderate work loads?
Are parts getting to be a difficult situation? I see a few of these units with low hours and wonder why they are so cheap.
thanks
   / L285 utility #2
I have an early kubota L285 as well, I use a 6ft box blade, and a small 12" homemade middlebuster. No reason a 30hp cant pull a sungle bottom just fine. Parts should be OK, try Messericks if you need something. Only problem with parts is they will quickly pass your total purchase price if you need/want many new parts.
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2013 Nissan Sentra Sedan (A50324)
2013 Nissan Sentra...
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A52128)
2004 Capacity Yard...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
1998 Kenworth Tandem Grain Truck (A50514)
1998 Kenworth...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
