Mowing L2800DT
   / L2800DT #1
rdh54
I'm looking at purchasing a l2800dt mainly for bushhogging and i have a 5 foot bush hog already that i plan to use. if i get behind due to rain, weeds may be chest high. would this tractor perform ok with the 5 foot?
   / L2800DT #2
Yes. I have a L2800HST. The only thing I didn't like on the DT was the lack of a double clutch so when you push the cluth to change gears (forward/reverse) the PTO stops, this would only be a problem if you were backing into alot of stuf as I was diong clearing my land.
   / L2800DT #3
I have a 2800 HST and it has no problem at all with a 5' mower. It has never bogged down on me no matter what I've thrown it at. Well, other than that time I ran it into a rather large cypress stump and broke the shear bolt :)
   / L2800DT #4
Really?
does that mean the blade turns forward and reverse??? :D
J
   / L2800DT #6
No it just starts and stops the PTO. with HST there is no need to push the clutch to go from forward to revers, on the L3400 they use a double clutch that when pushed half way lets you shift gears without stopping power to the PTO push the clutch all the way and power is stopped to the PTO
   / L2800DT #7
My L2550DT has a two position clutch. PTO is disengaged when clutch is FULLY depressed and then engages PTO prior to when wheel drive clutch engages. I can depress clutch to stop while remaining in gear and continue to rotate PTO under power.
Is the L2800DT different?
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
2017 Massey Ferguson GC1705 Compact Tractor (RUNS) (A50774)
2017 Massey...
2012 Cadillac CTS Sedan (A50324)
2012 Cadillac CTS...
Rack w/ Spray Rig Arms (A50121)
Rack w/ Spray Rig...
ASSET DESCRIPTIONS & CONDITION (A52577)
ASSET DESCRIPTIONS...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
