L2800 PTO won't disengage!
   / L2800 PTO won't disengage! #1
pax_tractor
SoMD
2010 Kubota M6040, '06 Kubota L2800 HST and 1948 Allis Chalmers G
My 2006 L2800 HST PTO is not properly disengaging when I select the off position on the PTO lever. Sometimes it works and sometimes it doesn't. I suspect it's a simple cable adjustment but I'm not sure how to do it. Any advise would be helpful; the manual does not mention this.
Yesterday I was putting in fence post and the posthole auger got buried because I could'nt shut the PTO off. Had to disconnect the PTO shaft from the tractor and use a pipe wrench with a hugh cheater bar to thread the auger back out. What a pain :-( Not eager to repeat that again soon.
Thx! :)
DaP
   / L2800 PTO won't disengage! #2
Check the cable that connects the pto lever to the linkage, they will sometimes get a "kink" in them at one end. Simple to replace and should be covered under the basic or drivetrain warranty.
BTW, take the cable with you to the dealer, they will have to retain it if replaced under warranty.
   / L2800 PTO won't disengage! #3
Next time you may want to try pushing the clutch in if it will not dis-engage when using the PHD.
   / L2800 PTO won't disengage! #4
Thx! :)
DaP
The L2800/3400 HST has a ratcheting over-ride clutch in the PTO that has a slight rake angle. This makes it hard to disengage under load. This may be why the PTO did not disengage while the auger was under load. You should use the clutch to stop if the PTO is under load. I would also check the cables though and be sure it is adjusted correctly.
The PTO on these units is not independent like the higher end models that will disengage under load.
Issues solved! Two problems; PTO wiring harness safety cut-out connectors were interfering with the PTO switch (poorly routed - factory job) and the lever + return spring into the transmission was corroded making return harder. I also took the cable out and lubed it. All works fine. Time to dig some more holes :)
2024 Case International 45C Tractor (RIDE AND DRIVE) (LIKE NEW) (A50774)
2024 Case...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A50323)
2015 Freightliner...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2016 Ford Explorer...
ATTENTION! PLEASE READ (A50121)
ATTENTION! PLEASE...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
