L2800 PTO problems again
   / L2800 PTO problems again #1
8226hamer
Indiana
Started with a B-20 Kubota, then B2910, now L2800
The PTO went out on my L2800 when I first bought it a couple years ago. I was running a 4' Land Pride tiller and the cams that mesh up from the transmission to the PTO shaft that engauge it sheared off. It had I think around 30 or 40 hours on it when it happened. After 5 weeks in the shop I got it back and have put at the most 20 hours of tilling time on it. I was using it today to put in a lawn in and the same thing happened again. My advise, if you are looking to buy a 2800 or 3400 and you are planning on running a tiller, I would go with the Grand L or B series of tractors. When I seen how the PTO was designed when my then, new tractor was split in half in the shop the first time, I knew then that it was a poor designed and would not hold up using ground engauging PTO driven implements. Parts are ordered, I will keep you all posted. This is the last time I will have this problem with this tractor. I'm looking hard at a B3030, or if I can find one a good used B2910. I had a B2910 that I put over 3000 hours on it and using no different than the L2800 and it never was down with PTO problems.
   / L2800 PTO problems again #2
I remember reading about your initial probem. I'm extra cautious with my PTO on my 2800 because of your post from a couple of years ago. It seems the PTO is the weak spot on the 2800/3400. I have tilled a couple of hours and haven't had any problems. I'm not tilling unbroken ground though. I made sure I got a slip clutch on my tiller shaft. I'll admit that if that happened to me twice, I would be looking for something else too. I will probably be shopping for a 3240 if I ever have pto problems with my 2800. It would make me sick to have to have a new tractor split in half for repairs.
   / L2800 PTO problems again #3
I can't say I blame ya on a different model with a different design PTO since you are having this kind of problems.
I don't even use my L2800 PTO for anything since getting rid of my rear finish mower so it should last forever.
Hopefully you will have good luck with what you get next.
   / L2800 PTO problems again #4
I have a L3400 and had the same problem. I think Kubota fixed it with a larger mechanism. I've had no problem since.
   / L2800 PTO problems again #5
Looking at my parts manual the HST PTO cam setup was changed after S/N 57745, and the gear models was changed after S/N 55199 and again after S/N 57745, I am not sure what the changes actualy entail
   / L2800 PTO problems again #6
My serial number is 54090. I wonder if mine has been fixed since it is before the serial number cut off. My dealer told me that Kubota had a big campaign to fix the problem, and sent teams out to fix the tractors made before the cutoff. He said the tractors that were before the serial number cut off that were fixed, were marked with a white paint mark on the axel- Like the mark on my axel, shown below.
I was never quite sure if he was feeding me a line of crap or not. I wonder if a dealer that posts on here could confirm this? You out there Messicks? :)
This is interesting. I took the tractor to the dealer to get it fixed and the service manager said nothing about this recall . I knew that I couldn't have been the only one with this problem. Thanks for letting me know about this. I will call today and see if they even know about this. The tractor is still there now.
   / L2800 PTO problems again #8
Keep us posted. I notice in the parts manual there is an "old" and "new" PTO countershaft listed. Under the "remarks" column, the cam kit is listed as "optional" below SN 55745. Doesn't sound like a recall, or mandatory fix. So, that leads me to believe my dealer is probably not telling me the truth with the whole "white mark on the axel means its fixed" story and the "campaign" Kubota had to fix the problem. If this is the case, that really ticks me off.
Volnavy, Is there anyway you can tell me what the parts numbers were that were used for the larger cams. I called my dealer today and informed them about this and the service manager said he would check into it. I have not heard from him.
   / L2800 PTO problems again #10
Tell your dealer to check the parts manual. Its right there in black and white. You can download a free parts manual for your 2800 from tractorsmart.com.
2015 Peterbilt 348 T/A Fuel Lube Truck (A50323)
2015 Peterbilt 348...
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
toro turf sweeper (A50324)
toro turf sweeper...
