L2800 PTO not engaging
   / L2800 PTO not engaging #1
rolandfarm
Just got my used 2006 tractor and tried to hook up the brush mower but the pto wouldn't engage. There is a 1.5 inch rubber boot attached to the pto handle on the bottom side. It is just floating in air. Any suggestions?
   / L2800 PTO not engaging #2
No bicycle style cable attached?
   / L2800 PTO not engaging #3
there should be a cable attached like HM said...
Look around for that... there is a known issue with that cable---
search here for it..
J
I did do a search before posting this but I guess I used the wrong words. I can see now that others have had this problem although some think it has been overstated. It may not make the radar screen at Kubota but it's a 100% problem for me. I have a 60 yr old Ford 8n with controls that work to this day. Is it not reasonable to think that a farm tractor should have a cable that will last longer than 3 yrs?
I'm not blaming the company or the tractor as a whole, I'm just surprised that this cable is that frail.
   / L2800 PTO not engaging #5
My PTO cable has been replace TWICE in 3 years, there is also a new and improved bracket for the top part of the cable assemble. The general consensus seems to be that periodic lubrication of the cable should help. I have made this part of my 50 hour service. I just use engine oil in a syringe.
It has worked fine since I started oiling it.
The fact that Kubota changed the design and has a service bulletin out tells us that they know about the PTO problems (cable and clutch)
I just returned from my friendly Kubota dealer that replaced my PTO cable for around $100. The biggest problem is borrowing a trailer and driving that rig 20miles, and then leaving it for a week. The mechanic said they have replaced a few cables but did not see it as a big issue.
I will get a syringe and keep this cable oiled on a regular basis. Thanks to all the responders and people in other threads who I have and will continue to learn from.
Tony
3001 (A51691)
3001 (A51691)
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A52748)
Quick Attach Skid...
Teamco Bale Grinder (A50774)
Teamco Bale...
2008 Nissan Sentra Passenger Car (A51694)
2008 Nissan Sentra...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2007 Ford F-150...
2013 Mack GU713 T/A Roll-Off Truck (A50323)
2013 Mack GU713...
