L2800 HST ratchet noise when dec throttle with PTO
   / L2800 HST ratchet noise when dec throttle with PTO #1
flakrat
Bronze Member
Birmingham, AL
Kubota L2800 HST
Howdy,
Just took delivery of my L2800 HST.
I notice that it makes a loud ratcheting sound whenever the PTO is engaged and I decelerate the throttle back to idle and when I push the clutch in.
I didn't read anything in the manual that mentions this sound. I called the dealer and he says that this is a feature that allows the engine to decelerate independent of the implement attached to the PTO.
Just wanted to double check with y'all to see if agree and experience the noise.
   / L2800 HST ratchet noise when dec throttle with PTO #2
My 3400 HST behaves in the same fashion. According to my dealer that noise is per design intent for the over-running clutch system; and does not indicate a failure or problem. However I believe that Kubota has instituted a warranty notice on this, and has a fix to quiet the noise to some degree.
You'd think that they'd put a big NOTE in the manual regarding this noise as it sounds like something is grinding up the gears.
   / L2800 HST ratchet noise when dec throttle with PTO #4
Man, I dunno ... grinding up gears is a bad sound. I bought an overrunning clutch for my BX when running the hog just to take it easy on my pto brake. It sounds just like a ratchet, cuz it is, but nothing like grinding gears ...
   / L2800 HST ratchet noise when dec throttle with PTO #5
Try disegaging the PTO without using the clutch and see if that helps.
Well, it may sound like a ratcheting noise, but to me, when I didn't know it was a ratchet, it just sounds like an aweful lot of noise.
Now that I know it's a ratchet, it does sound like one :) Just one of those things when you buy something and every odd noise makes you jump.
   / L2800 HST ratchet noise when dec throttle with PTO #7
This noise startled me when I first got my L3400 HST. I called the dealer and they said it is normal and faxed me the mechanical drawings showing how it works. It is what Kubota calls a slant cam. It is indeed a ratchet that functions as an over riding clutch. It also provides the means engage/disengage the PTO. The new fix to increase the oil level will damp some of the sound but it will still ratchet.
What I do is lower the throttle slowly and while the engine is slowing I disengage without clutching. No noise this way. The slant cam is unloaded while the engine is slowing so it should be fine. If you close the throttle quickly you also get the noise. The noise means that the implement is over driving the PTO shaft.
Never engage the PTO without clutching and never pop the clutch after engaging the PTO. Let it out slowly at idle to spool up the implement and then throttle up.
   / L2800 HST ratchet noise when dec throttle with PTO #8
Oh!, so this is a subsystem built into your PTO!? That's really neat. ... may have been around for years, I just didn't know ... which is the same line I use when the sheriff shows up /forums/images/graemlins/crazy.gif
Thanks for the link. I've printed out the pdf and will fax it to my dealer when I get closer to my 50 hour maintenance call.
Now if they'd just release an official warranty paper regarding the replacement of the 3ph valve with the 3010 valve.
Tandem Axle Silage Cart (A50774)
Tandem Axle Silage...
PT Pump (A50121)
PT Pump (A50121)
2011 Hyundai Sonata Sedan (A50324)
2011 Hyundai...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2017 Ford Escape AWD SUV (A50324)
2017 Ford Escape...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
