L2800 fuel gauge
   / L2800 fuel gauge #1
ffproulx
My gauge always shows full. I’ve removed the gauge abd it showed the level changing when the unit was out. Is that a ground issue. How do I check it. Thanks
Or is it a sending unit issue. Not really wanting to pay 90 bucks for a new one
   / L2800 fuel gauge #2
I recommend using a DMM and check resistance and continuity.
   / L2800 fuel gauge #3
Yup , also heres a quick check for the condition of the resistor ( Pot) in the float gauge assembly. Follow the lead up from the tank and pull the pin connector a part at the first terminal and put your ohmmeter red lead to the pin and the black to a good known chassis ground and move the float up and down in the tank with a coat hanger and see if the resistance changes. If no change you need a fuel tank gauge
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2022 Case IH Magnum 340 AFS MFWD Tractor (A53342)
2022 Case IH...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A53472)
UNVERFERTH 330 -...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
Cat TH407C Telehandler (A53472)
Cat TH407C...
