L2650D
   / L2650D #1
Ted
Garland, Texas
I am looking at purchasing a L2650D from a equipment dealer (used). He says it is a 93 or 94 model, serial # 60358. It has a front loader (LA450A), 4x4 shuttle transmission, ROPS, and 638 hours. I cannot find any information on this model. One new dealer finally said that it was probably replaced by the L3010. The tractor is priced at $11,200.00 The tractor is very clean and shows no signs of leaking. It is probably over powered for my current intended uses, but, that may change when I find out what it is capable of doing.
I can find very little information on the intenet about this model.
Is it so bad that no one wants it, or so good that no one wants to sell theirs?
Is the $11, 200.oo a reasonable price?
Thank you.
   / L2650D #4
I HAVE A L2650DT I HAVE ONLY HAD IT 2mo AND ONLY PUT 2HRS. ON IT DUE TO THE WEATHER IN OHIO IT CHANGED FAST. ITS NOT A SHOW TRACTOR ITS JUST A LITTLE UGLY DUE TO SOME HOOD DAMAGE. THE PEDAL ON THE LEFT SIDE WAS STICKING A LITTLE WHEN I GOT IT. I JUST USED A LOT OF PENETRATING OIL TO FREE IT UP. SEAMS TO WORK VERY WELL SO FAR. I HAVE BIG YARD AND WILL USE IT TO CUT THE GRASS . I COULD NOT FIND MUCH INFO ALSO!!!!!!!!WAS A GREAT DEAL THE DEALER JUST WANTED IT TO GO DUE TO WINTER..
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A55218)
LIKE NEW 2023...
2018 DRAGON 150 BBL ALUMINUM TRAILER (A53843)
2018 DRAGON 150...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2012 LEEBOY 8515B ASPHALT PAVER (A51406)
2012 LEEBOY 8515B...
UNUSED IRANCH IRMC HIGH END ELECTRIC MASSAGE CHAIR (A54757)
UNUSED IRANCH IRMC...
UNUSED LANDHONOR LHR-SP100 HYD SHOP PRESS (A54757)
UNUSED LANDHONOR...
