L2501 tack cable
   / L2501 tack cable #1
Scrutinizer301
Florida
Kubota l2510
Tack quit 2nd time with under 200 hrs. Fix if you buy an oem cable it can be changed i under 5 minutes. Intrested in learning how?
   / L2501 tack cable
Here is how you change that cable in under 5 minutes you don't have to take the dash cluster apart I removed the cable from the motor side and pulled it out of the retaining harnesses and let it hang straight down to the ground and shook it the inner part of the cable came out I took the new cable that I ordered and lubricated it seems to me they weren't lubricated quite well enough because where mine had broke it was kind of dry right there and that was an original Kubota part as long as both of your cable to our original Kubota this will work I slid the new cable up in through the old harness started the motor Left the cable loose at the motor end with the motor idling I engaged the cable at the Motor check to see if the meter was working it was so I shut the motor off and screwed it down tight no problem
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
New/Unused 13ft x 20ft Single Garage Metal Shed (A51573)
New/Unused 13ft x...
John Deere 310A Loader Backhoe (A52384)
John Deere 310A...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
