L2501 (Or all Standard L's) Air filter
   / L2501 (Or all Standard L's) Air filter #1
crashz
Veteran Member
NH
Kubota L2501, JD LT150, DR Field Mower
I have approximately 100 hrs on the 2501 and its been an absolute work horse. Great machine.
It gets run a full throttle or PTO speed most of the time, as bush-hogging and mowing is its main chore. It occasionally gets into heavy cutting and puffs a little black smoke when the governor lays on the fuel. Nothing crazy. A little smoke at start-up too. Absolutely nothing I would consider abnormal.
But the exhaust pipe exits at the air cleaner area. And at the 50hr and 100hr service, I have found the air filter to be completely black with soot. You cannot see light through the pleats but not so much that it would shake off. I have not tried to blow air through them, just replaced them. Anybody else run into this? The tractor doesn't seem to run any differently with a clean or dirty filter.
   / L2501 (Or all Standard L's) Air filter #2
I just changed my air filter on my L2501. This explains why it was a dark grey. It wasn't black though. Sounds like we are recycling our exhausts.
   / L2501 (Or all Standard L's) Air filter #3
On my L3200 the air filter has just been dusty each time. No soot.
   / L2501 (Or all Standard L's) Air filter #4
I would add and extension to the exhaust pipe with maybe a curved end to direct it away from the air filter
   / L2501 (Or all Standard L's) Air filter #5
No soot on my air filter on the L2501. You can wash and reused these a couple times with no problems. I just blow them out most of the time with the leaf blower....not real hard.
2015 Ford Focus SE Sedan (A50324)
2015 Ford Focus SE...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2002 Semi Deck Over Trailer (A50514)
2002 Semi Deck...
Frontier Forks (A50515)
Frontier Forks...
1270 (A50490)
1270 (A50490)
2015 DODGE RAM...
