L245DT low compression
   / L245DT low compression #1
scud
L245dt
Hi all,
I'm new to these forums, as I only recently started my tractor adventures.
I bought an old L245DT, which i knew needed some love, and have just started to work on it.
Current issue I am working on is that it is relatively hard starting. By that I mean it needs the full 40 second glowplug preheat, quite a bit of cranking before she starts, and that even on warm days.
Beside that, i noticed a bit of blowby from the breather tube.
What i did:
Compression test. All cylinders approx 300psi. Wet test makes negligible to no change.
Blew some low pressure shop air into the glowplug openings and listened. When valves are shut i hear a very slight hissing, but cannot tell from where. No bubbles in the water, loosening the little plug to gauge oil level doesnt seem to change sound either.
Next i did a squish test, and got about 1 to 1.1mm between all cilinders, so i am thinking the head gasket used is too thick.
However, before i dig any deeper, i wanted to check if there is anything else i should look out for, and whether or not i should change the piston rings while i am going to take off the head anyway.
   / L245DT low compression #2
Make sure your air cleaner is clean and the air path through the manifold is clear. I suspect you do need new rings but free breathing is essential.
Ah yes, good point. Filter is squeaky clean, as is housing and tube.
I did however notice on the intake, that cylinder 1 has quite some soot on the intake, while the others are clean. But im not sure what that means. Bad injector?
   / L245DT low compression #4
If you're taking the head off you may wish to consider a valve job. You may have some blow by. Are your glow plugs all good?
With a valve job, do you mean lapping the seats? I did set the clearance on them.
Glow plugs are indeed all good, checked those before.
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
2022 FORD E350 BOX TRUCK (A57880)
2022 FORD E350 BOX...
Red Cedar 2-Seat Wood Glider Bench (A55853)
Red Cedar 2-Seat...
10 ft Shipping Container (A55973)
10 ft Shipping...
DEUTZ MARATHON...
2017 COTTRELL TRAILER (A55788)
2017 COTTRELL...
