L2350 4x4
   / L2350 4x4 #1
tuttle
central oklahoma
komatsu d21a-7
front wheels not powered when in 4 wheel drive. does any one have brake down of gear box infront of transmission or know what i will find when o take this apart thanks tuttle
   / L2350 4x4 #2
I had the same problem. Put the whole tractor on blocks/stands and run it slow. I had grinding noises in the front axle. It turned out to be the bearing was seized around the spindle shaft ( axle was leaking when I got it, previous owner must have let it go dry too many times )and it all was turning in the axle and oblonging the casting..needed a new axle end-cap, gear and bearing.
( $900.00) total..don't mean to scare you..but listen to where the noise is coming from..If you don't hear anything, it could be as simple as the drift pin that locks in the FWD at the engaging pull arm..or even a u-joint in the drive-shaft..couple of scenarios for you to review
UNUSED FUTURE MINI EXCAVATOR AUGER SET (A51244)
UNUSED FUTURE MINI...
2016 Ford F-550 4x4 Ext. Cab and Chassis Truck (A50323)
2016 Ford F-550...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
Kinze (Delgelman) MT 201 High Speed Disc (A52349)
Kinze (Delgelman)...
UNUSED FUTURE MINI SKID STEER PALLET FORKS (A51244)
International 820 Platform (A50514)
International 820...
