L2250 question about a bolt...
/ L2250 question about a bolt... #1
jtaubrey
Aubrey, TX
Kubota L2250
20130615_100354.jpgI just bought a used tractor and have a small amount of fluid dripping from this bolt.. I assume is for the hydraulic fluid to drain but the middle of the bolt pops up and down if that makes sense. Is this bolt supposed to be that way?
You are soon to see the inside of that tractor... You will be 'splitting' it to repair the leaking seal.
Seriously? This is just a bolt on the bottom where it is coming from. I sure don't like the sound of that.
/ L2250 question about a bolt... #4
That looks like a water drain for the clutch. If water leaks out when you push up the pin, then remove the bolt to drain the water. The owner's manual should verify what I'm saying.
/ L2250 question about a bolt... #5
I'm not familiar with that tractor, but if it is as Wolfy says then the front transmission seal is leaking, as Kenny says. If it were mine, I would frequently check the tranny oil level and judge my response by how fast that changes. Sooner or later a new seal is in order.
/ L2250 question about a bolt... #6
Yup, that is what it is. If more than water is leaking out than it could be a problem.
Thanks...it doesn't seem to be leaking from the "plunger" so I guess that it is good. :)
/ L2250 question about a bolt... #8
Clean the area up with degreaser and keep a close eye on it to see if the oil is coming from the drain (could be a bad seal) or the bolt next to it. That bolt could be an oil drain or an oil passageway. Either way it should be sealed and it could be the thing leaking. Before splitting the tractor to replace a seal I would make sure I knew which was leaking.
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
6 ROW RIPPER BEDDER W/ROW MARKERS, 3PT (A62130)
6 ROW RIPPER...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A62131)
UNUSED WOLVERINE...
APPROX. (15)-16' HDPE PIPE (A62131)
APPROX. (15)-16'...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63118)
2019 Cadillac...
