L225 pto stalling
   / L225 pto stalling #1
collie
I have a L 225 when using the finishing mower in tall grass the pto slows down and stalls where pto comes out of the rear of the tractor. but the tractor rpm doesnot. gears work fine. Any suggestions?
   / L225 pto stalling #2
The PTO section of the clutch pack may be slipping. Do you smell any burnt odder coming from the clutch pack?
   / L225 pto stalling
it doesnot have slip clutch on shaft.
   / L225 pto stalling
found the problem.has a clutch pak inside of the casing.Took tractor apart,lookks like a overiding clutch.one way bearing was shot,newpak $525.00to much forme.I put a coupling ,same as thetransmission had joining to the rear end(same length &spline count as the pto pak was)in the pto .Works fine .going to buy a overiding clutch on the pto on back of tractor.
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2023 PETERBILT 579...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2008 CATERPILLAR 320D L (A50854)
2008 CATERPILLAR...
2018 Dodge Ram 5500 Bucket Truck - 4x4, Versalift VST40, 45FT Reach, Dakota Line Body (A51039)
2018 Dodge Ram...
AFE SSMM Disc Mulcher Skid Steer Attachment (A49461)
AFE SSMM Disc...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A51039)
2014 Doyle Dry...
