Snow L2185 Snowblower
   / L2185 Snowblower #1
JCYR
Kubota 3710
I have a kubota 3710 and am going with a front mounted snowblower. My local dealer saya the 72" snowblower is to big. Tractor is 37HP with 32 at the PTO. Does anybody have experience with this as to weather the tractor will handle this snowblower. Thank you
   / L2185 Snowblower #2
Those numbers are based on RAD (the people who make the snow blower for Kubota). I think for a 72" wide front mount blower they recommend more than 35 pto hp. Personally, I say BS. I have a 72" front blower on my 4240 (36.5 pto HP) and HP is not even close to being an issue. Normally I run the engine at about 2000rpm and even then with the reduced hp I don't have a problem.
On really deep snowfalls I open it up and run at full pto speed. But it's not because of a lack of HP but I do it so the impeller can throw snow as quick as possible. The biggest problem with a snow blower on the big snow falls is the restriction on the amount of snow that has to go into the smaller round impeller area.
If hp is ever an issue you can always go slower. It's not really going to cost you time because your removing the same amount of snow as a smaller blower moving at a faster speed. On your second pass there will just be less to remove. My advice, I'd get the 72" blower.
   / L2185 Snowblower #3
I've had my L3430 w/72" blower for five years now and have never had a problem moving snow. Last spring we got over 2' of wet heavy snow and though I had to go a bit slower it was still no problem.
   / L2185 Snowblower
Thank you all for your help. I guess im going to go with the 72. There seems to be an issue finding the mount to fit my tractor. Im not sure but I imagine I can retrofit a mount from another model tractor?
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A52128)
2019 New Holland...
1982 LeeBoy Motor Grader (A52128)
1982 LeeBoy Motor...
2006 DITCH WITCH RT40 RIDE ON TRENCHER (A51242)
2006 DITCH WITCH...
John Deere 702 Hay Rake (A50515)
John Deere 702 Hay...
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
2023 CATERPILLAR 259D3 SKID STEER (A51242)
2023 CATERPILLAR...
