L21 backhoe hose replacement.
   / L21 backhoe hose replacement. #1
Trafficman
Washington Grove, Maryland
Kubota, BX22
I have an older BT600 Backhoe for my BX22 that has developed a hydraulic leak. Since the leak appears to be in one of the hoses, and they are all original. Should I just replace the 1 leaking hose or (since they're all 18 years old) replace them all to forestall future leaks?
Thanx
Trafficman
   / L21 backhoe hose replacement. #2
Replace the one. Unless replacing the one requires some major disassembly that would cause other to also be exposed for replacement- this would be unlikely.
RNeumann,
The hose that is leaking is buried in the lower arm and will require the hose to be disconnected at the control box, pulled down the lower boom, up the arm, and disconnected from the bucket. Long hose, my concern is that since they are all 18 years old, they may all be on their last legs. I don't want to have to pulling out one hose after another if they're all about done. I've had hoses unexpectedly pop before and they invariably are a mess to fix and replace. I did replace the hoses on the FEL a few years ago one at a time, because they kept failing one after another. Very frustrating and more time consuming. That was only 8-10 hoses, the backhoe is 23 hoses, a good bit more $$ to do them all.
   / L21 backhoe hose replacement. #4
I believe you have answered your own question since you had this problem on the loader I would expect same result on your hoe of hoses continue to fail.
2001 MONACO KNIGHT MOTOR COACH RV (A53426)
2001 MONACO KNIGHT...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
3 1/2 FT DISC HARROW (A51247)
3 1/2 FT DISC...
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
