L185 problem
   / L185 problem #1
Anonymous Poster
Epic Contributor
Recently while using my L185 mowing I have noticed oil dripping from breather tube after engine gets warm, what would cause this? Only other thing is it starts real hard when engine cold, like only running on 1 cylinder and takes quite a few trys to start it, is this an injector problem? Runs good after it starts, no excess smoke out exhaust while running, any ideas?
   / L185 problem
The crankcase breather tube, hangs down under your engine a small rubber hose
   / L185 problem #4
Starting problem sounds like you only have one glow plug working. Check wiring and ohm out the plugs.
You do give the plugs plenty of time to heat up?
Rover
Irrigation Pump (A52128)
Irrigation Pump...
Year: 2013 Make: Chevrolet Model: Caprice Vehicle Type: Passenger Car Mileage: 73,798 Plate: Body (A50324)
Year: 2013 Make...
2014 FREIGHTLINER M2 DAY CAB (A51222)
2014 FREIGHTLINER...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2012 Cadillac SRX (A50324)
2012 Cadillac SRX...
2015 CATERPILLAR 745C 6X6 OFF ROAD DUMP TRUCK (A51242)
2015 CATERPILLAR...
