L175 Gear Lever Oil Leaks
   / L175 Gear Lever Oil Leaks #1
njrqs
Veteran Member
Queensland, Australia
Kubota L1-20 DT
Help...
I am getting oil leaking from on top of the gearbox where the shift levers go in. The oil level is OK. Any ideas ?
   / L175 Gear Lever Oil Leaks #2
Neil,
You may have a "o"ring or the rubber boot which needs changing,not sure if you have a gasket in that area.
Thomas..NH /w3tcompact/icons/wink.gif
   / L175 Gear Lever Oil Leaks #3
I had an L245DT which suffered the same problem and one day I happened to remove the plastic oil filler cap after running for several hours on a hot day to see if the oil was foaming. What I discovered was that the gearcase had built up some static pressure from heat expansion. Well I was pretty sure now the cause of all the oil around my gear shifts was just a lack of gearcase venting. The remedy was simple, I just drilled a small 1/8 hole on the side of the cross of the cap and cut a small piece of foam to fit snuggly inside the cap and act as a filter. No more mess around the shift levers.
   / L175 Gear Lever Oil Leaks #4
This has happened to me before, i have an L185.There is a small "vent pipe" on the transmission. This is under the seat. It gets glogged by mud dublers and wasps. dirt the usual. the small ELBOW [PIPE] will screw out. you can try to clean it with a small wire{guitar string} etc. but taking it off is much better. It is a little tricky too find, but it is there. this will stop your shifter leak and all other leaks. The transmission builds up pressure, and blows the oil out the shifter handles, if not corrected, it will blow out other seals.any other question, just email me.pepper@digital.net
Speedy Thanks !!
Found the pipe & yes it was fullof gunk.
Haven't run it yet but this sounds like the answer to my problems !
Cheers
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
2018 KUBOTA SVL95-2S SKID STEER (A51246)
2018 KUBOTA...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2018 FREIGHTLINER...
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
