L150 head lights dont work
   / L150 head lights dont work #1
ohio farmer04
new holland tn
put on a new battery cable
and know dont have lights
lights worked before i had cable put on skid loader 1 1/2 years old
   / L150 head lights dont work #2
others be able to help ya better. but the obvious.
have you checked the fuse for the lights?
when you put on the new cable, i am assuming there might have been another smaller cable and a larger cable that hooked to the same post on battery did you hook them both up. ((i am thinking cars/trucks)) and they normally have the one larger / one smaller cable. ((i don't have a clue about your specific make/model unit))
do you have a multi meter to read DC current / amps to test wires to see if you have power going to the lights?
big one, do you need your unit on and engine running to have lights? vs just trying key to "accessories / lights on)?
   / L150 head lights dont work #4
Does your L 150 have a hood that you had to remove to get the new cable on? If it does and you took it off, the headlight wire plug-in connector probably got pulled apart. Look for a connecting wire between the hood and engine compartment and plug it back togather. It runs the headlights.
2015 International DuraStar 4300 Ambulance (A51692)
2015 International...
Roll Off Dumpster Body w/ Assorted Tires (A51692)
Roll Off Dumpster...
2015 John Deere 544K Articulated Wheel Loader (A52377)
2015 John Deere...
2017 FORD F550 XL SUPER DUTY BUCKET TRUCK (A51406)
2017 FORD F550 XL...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
