OutbackL130
I've had my JD L130 since new and back about 8 years ago the hydro transmission went out, which apparently is very common for them.
The cheaper version of my tractor, the L100, came with a 5 speed Spicer transaxle which were readily available on the interent new for $100 VS a new hydro L130 trans for around $500.
So I decided to retrofit a 5 speed Spicer transaxle into my L130. It was a direct bolt on and just required various L100 parts such as the shifter, trans pulley etc.
I've been using the mower like this ever since and the spicer transaxle is a beast compared to the old hydro unit. It's reaching 600 hours and I use it to mow my 3 acres and drag a 4' harrow on my 700' driveway.
The only thing I still dont know having never driven a factory L100 is:
When moving are you supposed to clutch to shift like driving a 5 speed truck or is it supposed to be able to shift with out pressing the clutch? I have to clutch everytime to get it to shift, but for some reason I was thinking the L100 was semi automatic where you didnt need to.
Also, I want to change the tension of the clutch. Now I have know idea if the L100 acts like this from the factory, but when you let off the clutch my tractor is 100% GO in whatever gear you're in. Running full throttle for mowing, the tires spin everytime I let off the clutch from standing still. If I am on pavement where it has more traction it will lurch very hard no matter how easy I let off the clutch, the drive belt grabs and OFF YOU GO! I dont understand why the belt wont slip a little to give a smoother start up. Any clever ideas on what to do?
