Mowing L130 front wheels tear up grass on turns
   / L130 front wheels tear up grass on turns #1
lkaskel
Westminster, Md
JD l130
Help!!!!! When I cut around my trees which is a 7' circle the front wheels slide and tear the grass. I thought it was the older tires so I replaced them with new turf tires from Tractor Supply. They still slide. I am not turning the tractor at the tightest radius possible so I am confused why it looses traction.
Any help would be greatly appreciated!!!!
Be Blessed
Larry
   / L130 front wheels tear up grass on turns #2
check the toe in and make sure it's in spec, other than that idk
   / L130 front wheels tear up grass on turns #3
Check to make sure your deck is set up correctly, might be making the mower try to run straight.
   / L130 front wheels tear up grass on turns #4
My fronts were plowing something awful until I got it out of differential lock.
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
192013 CATERPILLAR 320EL EXCAVATOR (A51242)
192013 CATERPILLAR...
Rubbermaid 100 gal Poly Tank (A50515)
Rubbermaid 100 gal...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2003 PETERBILT PB 330 WATER TRUCK (A51243)
2003 PETERBILT PB...
Wolverine Quick Attach Stump Grinder (A50514)
Wolverine Quick...
