L111 engaging blade instantly stops mower
   / L111 engaging blade instantly stops mower #1
BThornton58
Hardy
L111 GT235
Hi all,
I have an L111 John Deere. It worked great last weekend now this weekend if you take off riding and engage the blade it instantly stops. If you sit still it runs fine until engaging the blade but instantly shuts down. Any thoughts on what this might be??????
   / L111 engaging blade instantly stops mower #2
Not sure of the cause, but try adding a little choke prior to engaging the PTO, it's worked for me on some JD mowers if they haven't warmed up enough...
Nick
   / L111 engaging blade instantly stops mower #3
Under the seat is a switch, it shuts off the engine when the mower is engaged if it thinks no one is sitting on the seat.
Check the position of that switch, if it's not in the correct place it won't register your weight.
It's happened to me a couple times.
   / L111 engaging blade instantly stops mower #4
:welcome: bthornton
Not sure just what "instantly stops" The engine? Forward motion? Mower blades?
Only happen when the engine is cold? Or when pressing forward pedal?
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
1984 GROVE CRANE (A54607)
1984 GROVE CRANE...
SCAN FOR HAULING AND FINANCING INFORMATION (A52706)
SCAN FOR HAULING...
2005 Big Tex 23ft T/A Flatbed Trailer (A52377)
2005 Big Tex 23ft...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
