I have talked to two Kubota dealers with in an hour drive. I want to hook up a grapple on my L 4400 Kubota with a LA703 loader , one of the dealers says he can put a switch on my bucket leaver on this tractor and the other one says it won't work on this model ! Will it or will it not work on this model ? Also i wanted to install 2 rear remotes on this same tractor, they priced me $1500.00 ,is there a cheaper way i can do this myself? Where can i by the parts that will fit this tractor for what i need to do without buying from these 2 guys. This is my first time to this site,so i'm sorry if this has already been covered. I will try to search for more info also.
You can save a LOT of money by installing the remotes yourself. Once you understand the power beyond, it's easy. Do some searches for "L4400 remotes" using the search tab.
I built a grapple with 2 hyd cylinders with a T fitting for the up and the down pressure for the front, i built it with the skid steer quick release attachment , and i'm building my quick attch for my loader now, as for the rear remotes i want to be able to run 2 cylinders open and close for my 3 point attachments like a hyd hay rake, or rear log grapple etc.
