L-4310 remote hydraulic
   / L-4310 remote hydraulic #1
BBELL
Bronze Member
Maine
Kubota L-4310 GST/ 1979 Ford 1700
I'm the proud new owner of a L-4310. Quite a jump from my 1979, 1700 ford. The question I have is on putting a valve bank on for rear hydraulic hook-ups. On my Ford I took the out line from my loader valve and ran it to the the bank for rear hydraulic and and back to the tractor, it works fine. Can I do the same on my Kubota, without damaging the hydro pump. One other question, with is the third line running out from my valve bank, one is inlet and second is outlet, what is that third one for?
   / L-4310 remote hydraulic #2
Contact TractorSmart.com . Kubota makes a kit for the L4300 series tractors.
For this application your spool will have high pressure line IN, low pressure line OUT which goes back to tank, and high pressure PB (power beyond) which continues the high pressure flow in the hydraulic circuit when the open center valve is in neutral.
   / L-4310 remote hydraulic #3
I've been looking for a 2 or 3 spool kit. Please let me know what you find out. So far the price has stopped me dead in my tracks but will need the hydraulics by spring 2004.
Rich
   / L-4310 remote hydraulic #4
Kubota's hydraulics are "power beyond". The remote block takes that into account.
If I were you, I'd add 1 complete outlet kit from Kubota and then put aftermarket splitters on the one remote to give you 4 instead of 2 outlets.
The Kubota remotes are pretty expensive. If the system was open center, they would be about 1/3 of the price.
2003 Lincoln LS (A50324)
2003 Lincoln LS...
2009 Lexus RX 350 SUV (A53424)
2009 Lexus RX 350...
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A53843)
2019 GENIE GS-1930...
UNUSED Clear Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Clear...
2007 National RV Dolphin 35FT Class A Motorhome (A51694)
2007 National RV...
