Ken
Veteran Member
Using the tractor yesterday the clutch quit. There was no prior problem and normal use is when starting and quick stopping with brakes. The GST function still is working and can use tractor.
The foot pedel has spring tension,lever into clutch housing is moving. There is no pressure as if the yoke is seperated from throw out bearing.
Any suggestions on what to look for. Or what to look for when seperating the engine from the transmission? Repair book looks as if normal type repair.
